Hello all,
I have a question on rear bumper mounting, on my 68 van I have to rear mounts to the left and right of the on the rear of the van. Then at the ends (round sides) there is a kind of supporting bolt and on mine they look to be large coach bolts which I am assuming are not original. In any event, I cannot undo them to remove the bumper so will need to cut them off and replace. However while scanning for parts, I only see some short bolts in the spares list which will not do the job, however under split vans I see they list a part called 'bumper distance tubes' which would seem to be what I need but are stated to only fit up to 67.
Might these be suitable even though my van is a 68?
If so, would these short (OEM Part Number: 113-707-191/C) bolts screw into each end of the tubes or should a long coach bolt be purchased to go through the tube in one length?
Any help or advice welcomed.
Thanks in advance.
Justin
Thanks in advance.
Justin
