Rear suspension Q?
ballbag
Aug 8, 2008
733
Winsford Cheshire
When I bought my bus I was told it was dropped 2 splines at the rear, after looking at other buses it seems a little high.
What do you think?
I want it to look like this really
I would say 1 outer only. I think if its 2 splines the spring plates will need to be notched, so that would be a good tell tale.
Mine was 2 and gone back upto 1 as ride quailty with a load in was poor. Now back at 1 spline and the rim just disappears under the arch like your first pic.
whs^^^^
If you drop it 2 outer splines
The ride will be crap - with virtually no suspension when loaded
The camber will wear tyres out within 5K miles
Your CV joints will wear out very quickly
Changing a wheel will be MUCH harder
But you may feel a bit cooler......................................
BJ1,
forgot about the neg camber/tyre wear and what a b%$%^d it was to change a tyre. But it did look much cooler.
Fit air bags, have cool n low and nice on long journeys :lol: Just not sure how you do that :oops:
The second pic looks close to my ride height.
Creative adjustable spring plates on the rear, as low as I can go without cutting/notching the chassis.
I did go down the King and link pin route with 3 1/2" dropped spindles on the front (and a 2" narrowed beam).
Other buses to compare are Ego's, Pete B, Grazy, Monkeyspinner.....and more I'm sure. Slammedresto has a similar stance but with balljoint dropped spindles.
I haven't found a cheap way to get this stance with a comfortable ride. But I am open to ideas.
All i will say is your bus is nice and deserves a few more inches.....the second picture looks 8) as
Edit: Easy to change a wheel with adjustables, but if you fit short shocks you will need to undo one bolt....2 minutes.
I dropped mine 1 outer I seem to remember.
It rides nice & is easy to get the wheel off.
