Gazmania
Active member
Hi folks, I've spent the evening adjusting the back brakes & handbrake cables on my '72 crossover, & all was fine until I went for a test drive & on pressing the brakes the pedal went straight to the floor. Pumping the pedal rapidly did give me some braking. There are no obvious fluid leaks from the system, & the master cylinder is still full. On checking the vacuum hoses I found one that didn't seem to be attached to anything, following it back, it terminated at the pedal side of the servo. I can't find any reference to this hose in the Haynes book so I thought I'd ask on here. What makes the problem worse is I'm on the Isle of Man - & we are booked on the ferry for Thursday night to go to Camperjam. Here is a picture of the offending hose which I drew on the servo page in the Haynes book. Any advice will be gratefully received.
Gaz
Gaz
