easy said:
I would always go for a vacuum advance on a stocker. Always seems to give the best results etc. As far as the air filter goes either is a good choice until you get them big carbs :wink:
Personally I think it is best to use a vac dissy on any setup, 009s can be shockingly poor quality since Bosch have stopped making them. If you are running dual carbs it would be worth getting them drilled and tapped for a vacuum take off. I was using an 009 with my baby Dells, I have since gone over to a late vac dissy and the performance is much more immediate and the fuel consumption has dropped by about 4mpg.
