james_stan
Hi all
Removed the side belly panels from my 1970 and as could be predicted it reveal some good and some bad points. The bad include rotten sills (inner & outer) which will need repair.
I started to trim off the outer sill (which was itself a repair ontop of the original outer !!) and I think I have made some initial progress.
I am happy to replace the outer sill and part of the inner (where needed)but I'm not sure about the middle track-runner part - can this also just be repaired without having to drill out all the spots and remove etc..
Heres some pics to be getting on with..
Here you can see the rotten front section and also the 'weld-over' repair panel to the rear (still in blue paint).
This one shows the old outer removed as the mid/inner part cleaned-up a bit.
This one from under the van - a shot at the front section..
One other question . The outer sill I am removing was repair by an 'overlap piece'. I don't want to use another of these. Can you still get the complete outer with the grooove/lip fro the doodr seal below the
slide door runner ?
James
slide door runner ?
James
