T2-Nate
Hi guys,
I've replaced all of the steering components, except the steering box.
All of the ball joints and tie rods are spanking new, and tightened.
The steering box has had a cleanout and degreasing, then filled with
bearing grease (not the VW-intended grease, but I read it's OK on TheSamba)
Now I still experience some play when steering, allthough I adjusted the steering box untill the adjusting bolt was pretty tight, steering is also heavier now.
What should I check before replacing the steering box (which is pricey so I'd rather not)?
