Storing the van
curly head
Apr 15, 2009
429
Upminster, Essex
When storing the van is it recommended to put on axle stands to stop the tyres from deforming? I won't be moving it for about 6 months
If on axle stands would it be too much weight on the small areas?
Any advice welcome
Any advice welcome
I put chalk marks on my tyres, and move forward or back a quarter each month. On the 5th month, I end up back on the original mark. So only a section of a tyre only gets 4 weeks at a time. That make sense?
Otherwise, axle stands or spare wheels with old worn tyres.
Place I used to work specialised in vehicle storage. They reckoned tyre deformation wasn't an issue unless parked for years. I wouldn't stress over a winter period of parking :D
Our daily car tyres are starting to crack due to low mileage, so best to keep driving through the winter!
As long as tyre pressure is correct and no punctures you should be ok
they are new tyres so I suppose it should be ok
apart from leaving the handbrake off and putting in a absorption tray thingy any other recommendations?
Ours were only about 1-2 years old, proper Goodyear tyres not remoulds or anything and they still started to crack, heading towards an MOT failure if it continues.
If its indoors then remove the battery, remove any soft furnishings such as bedding that may get damp, take down the curtains in case of mice etc that may eat them! Take out any food or crumbs etc and drain out any water from tanks. Leave windows ajar. Get it nicely dried out before you put it away and make sure its as clean as possible - give it a polish before you store it.
If its kept outside, then keep it aired and ventilated on nice days, open the doors and dry out the door shuts after rain. If you are tempted to start it up or drive it occasionally make sure you get it up to operating temperature so that condensation doesnt rot out your exhaust system.
Cheers Clem, good ideas
Full tank of fuel. Cuts down on the vapour and also lowers potential of condensation build up in tank, leading to rust.
Disconnect battery too - less chance of an electrical fire, and stops your battery going flat too.
Steve B said:
sparkywig said:
I wouldn't store it with a tank full of modern fuel, E10 will corrode steel and rubber if left for months.
Mmmm, fair point. Not really thought of that
Two good sites for anyone else who'd not thought:
http://ttypes.org/ttt2/ethanol-blended-fuels
and
http://www.groups.tr-register.co.uk/wessex/ethanol-update.html
Looks like some Super Unleaded 98RON may contain less E10 or none, if that's still the case?
Cheers Sparkywig
Ha ha ha poor old Essex, looks like Total doesn't t even want to visit!
Not sure now what's best, to drain or not to drain?
Also from a theft risk point of view I think I will remove the wheels after all, might slow the f*ckers down!
With regard to the fuel being in there ... unless you thoroughly drain the system then the risk of ethanol damage will always be there. As long as modern rubber hose is used on the van I wouldnt worry unduely.
