Stove gas problem. Calor or Campingaz??
markrockliff
Nov 22, 2014
15
Hi all bayers!!
I have one of those drop down stoves that you see in a Westy continental, or Berlin Helsinki.
So, the problem is, if i put my calor 4.5kg on, it leaks from the valves.
If i put a campingaz 907 with regulator on, the stove doesnt light??? but no leaks??
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Calor bottle runs at 6.9 bar pressure if used without regulator . DO NOT TRY THIS!!!!!!!!
Always use a regulator. Call a registered GAS SAFE Engineer as said .
You don't say what area you are. If close can check for you. Sure someone will be along.
J & P
:D :D :D
I sorted it
The Flame Failure evice on end of thermocouples had failed.
New ones fitted, up and running!!!
