Helloes,
I've now come so far to work on the engine on my resto
The engine is an industrial motor with a hand crank pulley which is a bit heavy at the end (worried it would be problematic for the crank), so wondering if I should leave it on, change this for the old pulley from my original engine, or get a scat degree pulley.
If I use either the hand crank (1 filed mark on it) or my original (many marks on it) I would like to find the degree template to correctly mark the 7.5 and 30 degree marks after I have found the TDC from piston no 1.
I have searched on here and can't seem to find a link to the printable template.
Or should I just stump up for a degree pulley, I don't like the look of them but they're prob more accurate than I ever could be.
Next question about strobe or timing lights what kinds do you use?
Found this one, has anybody used it?
https://www.machinemart.co.uk/shop/product/details/gunson-g4113-timestrobe-xenon-timing-light
Are there better/cheaper options?
Cheers.
Andy
Cheers.
Andy
