hi unless your talking about a rolling road session why not get a manual and timing light ect qand have a go you self its not as complicated as you would think
ive just put a set otf twin carbs on scat 35 but im getting poping and pinking timing is set to 7.5 as i have a 3 notch pully im just about to pull the engine out to do the crank seal so will check for air leaks when out
hi set your timing up as normal using a timiung strobe at tick over then when you rev up the timing should advance 30 degrees i think thats the right amount ?? if not check if vacuem advance that the lever to the vacuam can is moving
Not sure about people in the Cardiff area dude, but if you are cool to come to Bristol, i have just the man!
Call Interpro in Thornbury on 01454412777 and ask for Jason. He does rolling road sessions and complete tune ups aswell as all the other sorts of services you could need. Dont forget to tell him that Ez gave you his number for that extra treatment 8)
