View broken photobucket images
67westy
May 10, 2010
3,049
46
Lincoln
Sooo I mentioned in another thread that I had sorted another chrome extension that updates the images in the page you are viewing, this is all images (not just your own) and works on any site you visit. This may only be temporary as photobucket could break this in the future but it works for now.
So if you want to give it a try have a look at this thread belonging to Lee C and you should see lots of familiar photobucket grey images: http://forum.earlybay.com/viewtopic.php?f=2&t=38185
Then install the plugin from the chrome store: https://chrome.google.com/webstore/detail/ehoeoelfbhokhcialnddlcnapkocnael refresh the page and then they should magically appear :)
Feel free to share the extension on other forums that you use.
Adam
Once the extension is installed it should just work. You may need to refresh the page if it was already loaded before installing
Sent from my Nexus 4 using Tapatalk
sparkywig said:
Works on other forums as well. ;-)
Good good :) simple bit of java script so nothing site specific. Share it around if it works :D
Lee C said:
I'm thick as pig ****, can someone do it for me ???
Hi lee,
There are two options, first is to use the extension mentioned in this thread and you should see images working again, this is probably a temporary fix. Second​ is to use my other extension to permanently move your own images to a different provider. I will send you a pm in a little while with more detailed instructions of each and some screenshots :)
Adam
ive ran through the process to repair the image links but alot of the images were lost or didnt move i think we got some but not all
PM'd you :)
Just run the plug in and it works a treat. All of the pics are now back on my thread. Brilliant!
Thanks 67Westy
Mark
gas1man said:
:cry: :cry: Has not worked. Only some pictures have come through.
Any ideas please.
J & P
:D :D :D
Which thread was it on? Post a link up and I'll take a look
Just realised this is the view thread :) it's possible that your browser has cached the old image. So clear your browser cache or press ctrl+F5 on the page showing the old image
Hi , It's more than likely me.
So I am able to view all photo's however not my own images.
Is this due to the fact that the plug in is "View third party images only"
Thanks for looking into this.
J & P
J & P
Strange one, it should work with any images really. I'll see if I can reproduce the problem with my own images. Did you try pressing ctrl+F5 to clear the cache?
J & P
If it's your own images then I would use my other extension to permanently fix them and move them away from Photobucket :)
Is there any reason why it has worked on my MacBook but not iPad am I missing something? Thanks for any help received
Are you using chrome on the iPad? I know the android version of chrome doesn't allow extensions so the iOS version may be the same
Sent from my Pixel using Tapatalk
