wanted 1600 tp engine,
robster
Apr 19, 2009
11
Hi i'm looking for a 1600tp engine, long block or turn key, gotta be cheap and in fair condition, don't mind a few oil leaks, to fit a bay so ideally needs to have block drilled for support bar but not the end of the world if it hasn't. Also after a 34 pict3 carb if engine is not a turn key.
Cheers, Rob
I got what you need carb and long block you can have them for £500 actually I probably have nearly every thing for a turn key. Picking up my new 1776 twin dells tomorrow so taking the engine out of my van this weekend I may need a few bits of tin for the new one.
Cool thanks I'll be in touch over the weekend, basically I thought my engine was knackered but found out its just one of the twin carbs gone, depends on which is cheaper, new set of carbs or your engine. Where are you?
Cheers, Rob
Hi Rob,
I'm pulling mine tomorrow morning, its a turnkey Mexico engine about 10 years old. It has external oil cooler and filter. It works with no problems The lot is yours for £400. I'm in Dorset.
LV :D
Lordain Volley said:
Cheers, Rob
Hi Rob,
LV :D
That would be perfect if you were a bit closer, with work commitments at the moment I can't see that I can get down to pick it up, I will definitely keep it mind though, thank you LV
If Robster is not interested i may have an interest but dont want to step on Robsters toes.
i could pop round and have a look at the weekend. is it a bay engine (drilled fo rthe support bar) ????
Dave
Cheers, Rob
Hi Rob,
LV :D
Cheers, Rob
Hi Rob,
LV :D
No problem, Your are a bit of a distance away! If you don't get sorted give me a shout.
LV
