Where does everyone get there fittings from?
Bought mine from Speedshop. They had a righ angle connector that cleared the engine support bar.
Stupid ebay... you have to be exact with the search function, so "Torques_uk"
http://www.ebay.co.uk/sch/torques_uk/m.html?_nkw=&_armrs=1&_from=&_ipg=50&_trksid=p2060778.m2749.l2654" onclick="window.open(this.href);return false;
Pretty handy, and most items are posted same day so you'll get them the next (usually)... priced well too, so you'll save a fair bit over speedflo/aeroquip 8)
Awesome thanks great company im guessing im after a AN10 90mm? Would a banjo be anygood? They use these on high end turbos, abd wouldnt they take up less room? Cheers
Banjos can restrict the flow a little, but I've used them for supplying an additional external cooler with no issues :cool:
Ok so i wont bother i found a few 90s at home with a big enough threaded end to fit my case its only a 5 mm hole i suppose if i clearenced it abit it should be ok? Whats the smallest hole i should go for?
Paul Weeding said:
Torques on ebay if you want aluminum fittings :cool:
Their stuff is awesome! Used fitting and hose from them on my 2110. -8 for oil lines to the filter and cooler, then -6 for the fuel system.
