Window Seals
mattd1984
Mar 8, 2009
2,473
Langford
Can anyone help, im replacing all my window seals on my deluxe! got some of the rubbers replaced and back in but havent attempted the crome trim yet, got the tool from heritage but cant really work out which fitting to use on the tool.
Any idea's pictures would really help.
Just tagging this one as it is a to do job for me in the next month once headliner is sorted!
I did think that the trim strip was suposed to go through the tool and as you run it through the rubber it opens up and the trim pops in with a little help....................... i may be wrong though!
Ben ;) ;)
Yep, the same principal as the dormobile pop top window claytonrite seals, run the strip through the eye of the tool and then use the tool to open the rubber valley whilst pushing the tool along and feeding the trim strip in, easy on straights, a bit more tricky on corners ;)
Hi Guys well i tried it this weekend. Got the rear and window behind sliding door seal fitted (without the deluxe trim) Then on Monday took out the opening quarter light and 3/4 window.
A total nightmare thort i was going to have to board it up in the end, first took a good 2-3 hours to get the quarter light seal in. Then another hour to get it to close. Then couldn't get it to locate in the correct place in the van so ended up just ind of fitting it and putting the 3/4 glass back in to hold it in.
Tried using the tool to open the gap and slide the trim in but it just wasn't having any of it. Has anyone got any pictures of which tool they used as the kit comes with several sizes. Im totally stuck hear guys any help would be amazing. Cheers
