Wooden Curtain Batons for Dormy Roof
Campervanman
Jun 10, 2012
65
Gloucestershire
Hi all.
Does anyone sell the wooden batons for the curtain rails to fit to in a Dormobile roof? Or does anyone have the dimensions to get some new ones cut? (I'm guessing that might be the easier option).
One final thing, are they just glued on to the roof?
Thanks.
I will bump this one as I need to know this as well!
Thanks ScutterBob,
I'm going to call Jim Bullock tomorrow at Dormobile to see if he has any ideas or can point us in the right direction.
I'm sure any wooden baton will do but I still need to know the correct length and how to fit it securely so it doesn't fall off at the first attempt to close the curtains!
:anim_39:
Just saw this - the are just bonded in to the glass fibre roof. No screws or such like.
Will nip out and measure for you now :)
1800 long
15mm wide
5 mm deep
May vary I'm sure but this is the size of mine - good luck :D
Spoke to Jim and he recommends 15x15 timber with epoxy to fit it. So I guess that's referring to the width and height/diameter of 15mm? Length of 174 to 180cm sounds about right.
Ok. Depth shouldn't matter too much but length will as you want your curtains to cover the glass totally ;)
