Emergency box
My box in the bus has fuses, plugs, points and condenser as well as assorted nuts and bolts ,tape and electrical wire and terminals and a selection of cheap spanners, screwdrivers, pliers and sockets.
this is what I have:
  • Breakdown Cover
  • Accelerator Cable
  • Clutch Cable
  • Fan Belt
  • Coil
  • Points & Condenser
  • Spark Plugs
  • Plug Leads
  • Dizzy Cap
  • Rotor Arm
  • Fuel Pump
  • Bulbs
  • Fuses (blade type)
  • Electrical connectors
  • Nuts & Bolts
  • Rocker Cover Gaskets
  • Oil
Looks like you're ready to do a service at the drop of a hat :ROFLMAO:
What would you bring with you on a longer trip, in form of spare parts etc? Trying to out together a list
/ Micke. The worrying kind
If your bus is in good condition and well serviced I cant really think of anything that could go wrong. If you haven't changed your clutch and accelerator cables in a while then maybe do it before you go, same with the fan belt. I've always used electronic ignition and never had a module fail, I did spit out a sparkplug once around 5miles from home after a 1500mile trip but just screwed it back in.
In fact the only time I broke down my coil failed, it gave me lots of notice in the form of a misfire after about 80miles, it was at this point it got sufficiently warm to cause the fault, I didn't know this was the issue at the time but a few months later it failed on the motorway and I got recovered home. Weirdly the replacement failed a few months later but this was in the garage and it wouldn't start. Never changed one since.
I did have a loss of power once on a roundabout down in Cornwall, managed to get to a safe place and pull over. The fault was the HT lead from the coil to the dizzy cap came off! How it still drove is a mystery but a simple fix at least!
Since I've fitted the Corvair motor (10yrs ago) I have never had an issue, other than a fan-belt & coil I don't carry anything.
It doesn’t matter if the trip is short or long, I always carry:
Accelerator cable
Clutch cable
Fan belt
Rotor arm
Spare bulbs
Fuses
Rocker cover gaskets
Oil
WD40
Tyre repair kit
And enough tools to fit the above.
I better get my act together, seeing how prepared you all are is giving me anxiety.
I've got most of those bits in peoples lists put here or there, but not kept in the bus apart from fanbelt, oil, starter fluid, fuses, test lamp, tools.
This will get me into action.
Conscious of it not becoming another hoarding space like our families Devon Moonraker used to be when i was a kid. Nowhere to put anything for the sake of stashed VW parts.
I remember someone on here used to carry a trolley jack :ROFLMAO:
Is that not normal?….
No lie, it was on my list, if I could work out somewhere I can stash it.
First choice would be under the back seat but I have an amp & speakers under there.
I considered any cable or brake related failures would involve me getting underneath to sort it. It’s too low to squeeze under without jacking it up.
a high lift bottle jack is a decent alternative and takes up a lot less space.
That's what I have
Never get under your bus just jacked up, always get something solid in there even if it’s a spare wheel and a block of wood. But carrying a trolley ain’t a good use of space. Whatever jack you are carrying and whatever spare you are carrying, have a practice at home, can you get the jack in there when the tyre is flat ? Can the jack get past the point needed to change the wheel from flat and both of these on all four corners too. I don’t like getting under with out decent axle stands minimum. If it ain’t solid, I don’t get under,,,,ever. When you service your bus and change stuff, if it was just servicing, keep the change out parts and bag and tag them, date, mileage changed, working order and why changed. These spares will be great because you know they work. Fan belt especially , bag it and tag it, sealable freezer bags are great, triple loop it and bag and tag it. it’ll get you home and you know it fits as replacements aren’t always available in ten minutes. Oil, at least a litre usually two in ready to dispense containers.I use one litre ex 80:90 gearbox oil containers complete with extension pipe and screw caps. Two of these in an Asda bag in the corner under the bed or behind the battery. Some electrical connectors with the screws, great for joining cables too. Electrical tape, wires fuses. Dissy cap, condenser, points, rotor arm, One long HT lead. 12V tester, spanners ,mole grips, pliers, sockets especially for the plugs and for the wheel lugs. Battery jump leads and a big old hammer just about does it, oha fuel pump and a matched rod..
Ozziedog,,,,,,,,,,,I bet there’s more too. :)
That's what I have
Webber do a great high lift bottle jack. I got one on market place £25 quid ish never used. Chap had four brand new in exchange for a debt. Something about an ex commercial mechanic was getting them from possibly LTs or Crafters or possibly Mercs . Thought I’d bought a pup when I got home as the base was slightly curved. Apparently that’s the new thinking on high lift jacks as they’ll always lift in an arc of some description.
Ozziedog,,,,,,,,,,works fab :)
I don't even carry a spare wheel, so certainly not carrying a trolley jack lol
I’m with ozziedog when it comes to getting under a bus. If I don’t have a jack stand I’m not crawling under. I don’t know the exact details, but we lost a great VW mechanic to an accident related to a bus rolling off a stand and crushing him. (As I recall he was originally from England.) Even when I’m using jack stands I do the “bump test” by trying to push the bus from side to side to make sure it’s stable.
It’s been drummed into me from working on VWs since aged about 12 to always chock beneath a vehicle. If nothing else is handy, the wheel you just took off is better than nothing else as others have said.
I got a few pieces of cut down railway sleepers, and coach-screwed metal handles onto their ends so they can be slung under and pulled out easily.
These larger lumps are stored against my garage wall, but this thread got me making a smaller pair from some hardwood i had that I can keep in the van somewhere.
My interior cabinets design clashes with the spare wheel location. I’d removed the roofrack to get our bus into our garage, since then I haven’t carried a spare wheel, which is risky. That bothers me so I need to see if I can modify or reduce the cabinet length, to make the spare wheel spot accessable again.
I’ve got a variable approach that I’ve taken on. I used to roll for years and years with no spare whatsoever. I’ve taken a slightly different approach now. I’ve got a slightly smaller tyre on a wide five steelie a 165 60 14 from memory from way back when I ran lowered. This fits nicely into an Ikea bag then another Ikea bag over the other side. It keeps wheel and rubber crap in the bag and not all over the inside of the van. It mostly lives in the boot section just sat flat on the bed. It can also nestle up alongside my new units I’m fidgeting with right now, or it can lay on the floor alongside the units. When I rock up anywhere fora bit of camping, I lob it just under the van a bit and it’s my step and mat, I have a circle of quarter ply in the bag too ,or it could go straight under the van.
IMG_4783.jpegIkea bags are less than a quid and you can replace them easily enough but they’re pretty tough. Reckon, on a warm day, you may stretch them over a slightly wider tyre then they’d stay that way.
Ozziedog,,,,,,,,,, Just check the wheel on all corners :)
