chris7ian
- Joined
- Jan 16, 2007
- Messages
- 47
- Reaction score
- 0
Hurst style Ball'n'trigger EMPI bus quick-shifter with reverse lock-out for sale (…and breathe!)
The pool ball gear knob will be replaced with the standard black item.
The shifter's been in my Bay about 3.5 years since I bought it new and will include fitting instructions, mounting hardware (2 longer bolts) and both spacers (you use one depending on which year bus it's going into)
They're about £70-£75 new - I'm after £35+p&p as it has a little bit of wear'n'tear but still much 'tighter' than a standard bus shifter at some point in the future the four studs through the steel/urethane block at the base could do with being replaced with nut&bolts (I had this done on my Bug one a few years ago with no drama)
I'm selling as I fancy a change. As such, the shifter is still in my bus and if it doesn't go I'll keep using it - I don't want to end up with 2 shifters so can't spring for a new one 'til I know this one's sold!
thanks
c7
thanks
c7
