matt-me said:Tofufi, if you're following this i see on the VZI thread you went down this route, are you happy with the outcome? Also with ICT's do you know if i am likely to find the same markings within the carb than that shown with the Kadrons; are all these carbs similar in the way they are made up, just different names and probably quality?
I am happy with the performance - the engine was smoother to accelerate with the vac distributor. Sadly, a month after getting the kadron tapped for the vac advance, I took it off the road for a restoration (on-going).
I've now got hold of another pair of kadrons, which I am thinking of fitting to my bus. The first thing I did when I got them home was to PM 'Fredster' on VZi to ask him if he would drill it for me. He did my first one
The carbs work on the same principles, but I can't swear that the ICTs will need the drilling to be done in the same place. I'd imagine someone out there has a guide to it if they don't come with vac connections as standard? The kadrons are renowned for being a bit thirsty, but I got reasonable MPG from mine in the bug.
