1968 Roadrunner Camper Bus
Bryan67
Mar 19, 2011
128
Fresno, Ca.
I`m wanting to sell the Bus so I can move onto another project.
1968 Roadrunner Camper for sale. When purchased 5 years ago this Bus had been sitting since 1982. It has since been on the road for the past 2 years. It is 90% original L282 Lotus White paint. The nose and both rear corners have both had dents repaired and repainted. It is very solid with no rot at all and only minor surface rust underneath and on the body. The rear upholstery is all original and could use the seams restitched to be like new. I still have the right rear closet and will include it in the sale if you like. The front seats have been re padded and upholstered in red vinyl and cloth with matching red TMI door panels. This Bus is extremely reliable, runs strong and cool, rides fantastic and turns heads wherever I drive. My price is $22,500. No trades except for Pre 1970 Type 3 or pre 1968 Type 1 Plus cash. Call look is preferred. Here is a list of what else I`ve done..
2276cc
New engine case
Forged 82 Bugpack crank
5.5" CB I beam rods
Engle 110 cam CB lifters
044 heads 40x35.5 round ports
CB solid rocker shafts with stock rocker arms
HD oil pump full flowed Berg cover
Cima 94mm pistons and cylinders
German valve covers vented
1.5" A1 sidewinder exhaust with heater boxes
Swivel feet adjusters
Chromoly pushrods
40mm Dellortos
Gene berg pulley
92 pass oil cooler with fan and 180 degree thermostat switch
Stainless braided oil lines
Powder coated tin, engine support bar, gas tank and filler
Rebuilt trans with 4.56 ring and pinion
4" narrowed factory beam by Franklins motor works
Wagenswest 2.5 inch drop spindles and 3.5" drop plates in the rear
KYB GR2 shocks
Rebuilt center pivot pin
New drag link and tie rod ends
New ball joints
Late model Baywindow disc brakes
New bearings, rotors and calipers
New brake shoes and wheel cylinders
New brake hoses
New master cylinder and reservoir
All new german rubber and window scrapers
Flat Four 5 spoke wheels
Toyo Proxes 185/55 and 185/65 tires
Powder coated bumpers and dash
Berg Shifter
Aluminum e brake handle and gauge trim rings
16.5" Lecarra leather steering wheel
Wolfsburg west under seat mats
New windshield
NOS german turn signal lenses
New Bosch alternator and starter
Buttys Bits throttle pedal linkage
Powder coated splash pan
All new German door and window rubber
Original black California plates
Original side tent and frame
http://www.thesamba.com/vw/classifieds/detail.php?id=1741796" onclick="window.open(this.href);return false;
