5 speed T25 box, anyone looked into it?
SiDev
Nov 12, 2013
576
47
I've had bays with 6 rib boxes which were ok, but would love a 5 speed. The T25's are common enough, but has anyone looked at the possibility?
I wouldn't bother... 5th on a T25 box is pretty much the same as 4th on a 091 2l box...
1st on the 5 speed is like a low ratio towing/hill start gear :cool:
5 speed t25 boxes are side shifters (instead of a bays nose shifter) so you'd need to run a new conduit front to back and make new linkages etc.
As Pauls says, not really worth the hassle.
Most t25 5 speeds seem to have diesel ratios i've found too as i can't find a replacement for the one in my petrol t25. :(
Thanks for the feedback gents, obviously a fair amount of work for not a great benefit.
Perhaps a little predictably, I'll add my 2 cents...
As an alternative to the T25 box, have you considered the Porsche route? I've fitted a Porsche 901 gearbox (5 speed) to my bus. It has roughly the same 4th ratio as the stock bus 4th gear, giving 5th as a sort of overdrive. As I've only a 1600 it makes a huge difference to how comfortably it cruises without sacrificing the ability to go up motorway hills without dropping to third (as I'd need to with an 091 and a 1600 engine).
The only downside is that first, second and third are taller than stock, making it feel slightly slower off the line (0-20mph) and I fear it will be a little less capable on steep slow speed hills, off road and on snow. To counter this, I'm considering (long term) building a slightly larger CC engine to go with it :)
More info on my conversion can be found here:
http://forum.earlybay.com/viewtopic.php?f=4&t=60286" onclick="window.open(this.href);return false;
