Just pretty much starting again with my wiring as previous owners have been at it!
Its a bit weird as mine is swedish van - according to the diagrams on vintage bus website, it shouldn`t have hazards, but mine does have the switch.
It only has one flasher unit with 3 connectors labelled KBL 49a 49 and then the standard headlamp dip relay.
I think someone has retrofitted the hazards in there possibly! When got the igntion on, none of the indicators, hazards worked anyway so i`m starting from scratch!
It has one of these for the hazard switch -
One of these for the flasher relay -
I like to have the wiring correct in my vehicles so normally rewire them to factory spec, but it would be nice to retro fit the hazards in there and the flasher relay doens`t look like the right one anyway!
I have a 10 fuse fusebox.
I`ve been going off this diagram -
http://www.vintagebus.com/wiring/Transporter_from_August_1967.jpg
(althogh i`m not sure what those 2 fan things are marked V2!
Are there any guides to retro fitting hazards into a euro spec 68 bay and secondly - can i use that flasher relay?
CHeers, MIke
CHeers, MIke
