I'm going to be buying a air shock kit for my front end but wasn't sure the best way to figure out the how to get the correct length shock needed . These will be going on the front .
I'm fitting a 3" narrowed adjustable beam with 3.5" dropped spindles .am I correct in thinking I adjust the beam to the height im after then measure the gap between the top and bottom shock mounts .I assume the Monroe shocks run with no air then when you want to raise the veichcle slightly you add the air pressure to the shocks ?
