Alternator price problem at JK, HELP
clyde
Oct 5, 2006
2,879
Lost in Space
First things first
The £55 deposit you pay on the Alt? will they take a Gen in return?
Why is it cheaper to buy all the bits seperate rather than as a bundel, sort of defeats the object.
Wont the Alt fit on a Standard Alt/Gen stand?
Why do you need a new fuel pump
Also isnt having an internal regulator a problem, ie if the reg goes for any reason your Alt is goosed.
Need help before i buy on monday
The surchase is release when you return another alternator not generator.
The pedestal is a different shape to a generator one, so needs to be changed.
Depending on what fuel pump you are running, it might foul the new alterantor.
The rehulator is a set of diodes that can be changes in situ for about £20.
The other thing they don't tell you is the standard carb linkage on the right, that makes the accelerator pump move can foul on the new alternator too.
There is a little trick you can do if you find an old 1300 carb, you can reverse the linkage to clear. It's near impossible to explain, but I have done it many times.
