richlowndes
Active member
- Joined
- May 18, 2008
- Messages
- 31
- Reaction score
- 0
I had an alternator conversion last year and all has been fine till now...
The generator light in the dash is on when the engine's running, and the alternator is not charging the battery. I can get it to start charging by shorting out the two terminals on the alternator. It will then charge until the engine is switched off.
The +ve feed from the dash is working fine and there are no short circuits between the generator light and the alternator (I have replaced the wire to be sure and it makes no difference).
When the engine is off but the key is turned to the on position, (without starting the engine) the generator light should be on, but it flickers between on and off constantly and sometimes doesn't come on at all.
Any ideas? I'm reluctant to fork out for a new alternator.
Richard
Richard
