Passion 4
The front of the white caseing has yellowed from sunlight, but otherwise in good condition.
If you have excessive moisture or problems with damp and require a Heavy Duty Dehumidifier without breaking the bank then the Amcor HD320H is the one for you.
A 7 litre tank, 22 Litre per day extraction rate, 2 speed fan, and large wheels make this a practical solution, whilst a washable Dual Filter system removes odours and dust and no extra filters need to be purchased.
• Extraction rate up to 22 litres in 24 hours at 32 degrees C, 90% Relative Humidity for faster drying
• Portable and manoeuvable for quick and fast drying where its needed
• Ideal for basements & unheated properties
• Aids the drying of laundry.
• Suitable for 4-5 bedroomed home up to 220 square metres.
• Large 7 litre water tank with warning light and auto cut-off
• Easy to use controls with variable humidistat and quiet 2-speed turbo fan controls
• Intelligent de-frost system and continuous drainage facility
• Wide operating temperature range 5 - 35 degrees C.
• Electrical consumption 370 watts for dehumidifier on maximum plus 800 watts with heater on maximum for low cost operation and maximum performance
£60
£60
