Passion 4
This is an Apple/Harman Kardon iSub 2000 Subwoofer
This beautiful Apple/Harman Kardon subwoofer was created for USB-equipped (older style) iMac computers. It is perfect for hooking up to your G3 or G4 (flat panel) iMac as it was designed to compliment the Harman Kardon built-in speakers that Apple were using at the time.
This 20-watt powered system includes a 6-inch woofer, delivering low-frequency bass response down to 44 Hz. With an easy, plug-and-play USB digital interface, the subwoofer comes with its own power supply and is optimized to work with Harman Kardon built-in speakers or Apple Pro speakers
Technical data:
Drivers: 1 6-inch woofer
Power: 20 watts
Frequency response: 44 to 180 Hz
Operating system: Mac OS 9.0.4 or later
Interface: USB port
Dimensions: 9.15 x 10.16 inches
Compatibility: G3 iMac computers with slot-loading CD or DVD drive, including 350MHz iMac, iMac DV, and iMac DV Special Edition & all G4 iMac Flat panel (not including iMac G5).
(Note: The iSub is not intended for use with Power Mac G3, Power Mac G4, or PowerBook computer
£60 (posted to anywhere in mainland UK)
Technical data:
Power: 20 watts
Interface: USB port
