Campmobile70
There was two plates, but bolts wasn't long enough to use the larger of the two spacers
I know every one raves about Berg shifter, and I drove a Bug with one the other day with one fitted and I was impressed with it, any ideas what I'm doing wrong??? Standard shifter back in place.
As you can see with the larger spacer there is not much thread left to bolt into the floor, is it as simple as just using longer bolts and larger spacer?
