Dirty Harry
Yesterday i noticed that the plastic transparent brake fluid line that runs from the bottle under the dash to the reservoir on the MC is sweating brake fluid, the same on my silicone lines from the bleeder bottle.
Anybody with the same problems, should i replace it and wich line to use?
There is some special bleu line for brake fluid but the inside diameter is only 7mm and i think i need 10mm or so!
Oh yeah i'm using Dot3 fluid from ATE.
