Zcat7
- Joined
- Apr 12, 2010
- Messages
- 670
- Reaction score
- 11
- Location
- Oxfordshire
- Year of Your Van(s)
- 1972
- Van Type
- Crossover
Popped the engine out today to try and fix the leaking oil cooler. All was going swimmingly well until I had occasion (while retrieving a dropped washer) to brush against an engine stud and felt it rattle...
So the crux of it is that the lower rearmost stud of number 4 cylinder (l/h bank) has snapped and left the stub in the block - think worst 'place' scenario here. I have never stripped a VW engine to this degree so I'm interested to know:
a) What is the minimum I need to dismantle and what parts would I need to replace (piston rings, pushrod tubes, gaskets etc)
b) Has anyone sucessfully retrieved a broken stud from the engine case before and if so how (I've never had much luck with thread extractors but was thinking of trying to weld a small bolt or something to it if there is enough space?)
c) Is there a sinister reason that has caused the stud to break and could I have further damage to fix?
d) Should I pretend I haven't seen it and just put everything back together...
I'm optimistically hoping for good-news responses but suspect that there will be tears. Please be gentle
Neil
Neil
