Right - got to tackle my indicators as I'm fairly sure my switch is buggered but with them being best part of £100 I want to be sure it is the switch before buying. Electrics are not my strongpoint, but is this roughly how indicator circuit works:
1. 12v pos comes from battery, thru headlight switch then fuseboard then hazard switch to indicator relay.
2. When indicator is turned on by lever, the 12v signal (pulsing on/off now after passing thru ind. relay) from relay is connected to relevant indicator terminal on switch and on/off signal then makes its merry way along wire to indicator thru bulb and to earth.
Is that roughly how it works?
At present my hazards all work fine, which suggests to me the hazard switch and the relay are functional. When I indicate left or right nothing happens and the gen light comes on. Genny output is not award winning (bought new one today) so my theory is that signal from relay is being fed to earth by dodgy switch, causing current drain and genny light on. I would have thought that a fuse would blow, but there you are.
cheers in advance
fred
cheers in advance
fred
