dizrythmia
Active member
This is ending on EBAY tomorrow, item 171402423892. You can find more photos there. hoping for £1750.
Finished in a two tone bronze and deep plum colour metallic custom paintwork. It is fully Veltrim lined with two frosted port hole windows in the sides and a large clear window in the lifting tailgate which has a thermo mat supplied, there is an opening skylight roof vent for extra light and fresh air. It is fitted with a RCD fused 240v mains hook up system with a switched spot light and single socket as well as a battery powered LED light. There are two stabilizing feet at the back which double as a jack when used with the front dolly wheel.
There is a sofa with storage underneath which turns into a bed with there aid of two boards. There are shelving compartments and a fold down work space for the one burner gas stove and stainless washing bowl. It has a table which clips to the outside of the pod for outside dining. The tailgate doubles as a rain shelter if necessary. It has recently had two new wheel bearings, has good tyres and comes with a wheel brace and wheel lock.. Size is 1500mm wide 2700 long and 1700 high
There have been written decals applied to the bodywork in the past and in certain light you can see where they used to be, probably needs a compound or t-cut. The back of the tail gate has a bit of crazing on close inspection and the top of it has laquer lifting. It does have a few scuffs and chips to the paint but still looks nice. One port hole is cracked on the inside laminate of the glass but remains watertight due to the complete outer glass.
