slammedkustom
the bugpack kit flows the oil out from the oil pump via a new pump cover and back in via the oil pressure valve. its the big flat headed screw thing under the engine near the flywheel end. you get a new fitting for it
you might have to fiddle with the rear brace bar a bit for clearance on the pump cover :wink:
1641s always run hotter due to the thinner barrels much like the old 1835s. every 1641 ive ever had ive converted back to 1600, no more problems!
