Do the side windows (middle and rear) really use the same window rubber? With the rubbers being shaped for the 90 degree corners in the middle window, do these moulded corners really 'flatten out' enough to go round the 'rear upper' corner, on the rear side window, smoothly, with out looking 'bumpy'. Bit hard to explain that - hope it makes sense!
Secondly, when putting the windows back in with the new rubbers, do I push them in from the outside, and pull the rubber lip over the metal from the inside, or the reverse? I expect it will be obvious when I look at them, but not quite at that stage.
