jenna_uk22
i've only got one plate behind the seat too... my other one rattles around the ash tray :lol:
Araon said:12 107 465 E
030351 A02 013 507 508
11 2 7953 UA 2310 21
12 - 1971 bus
107 465 E - serial number
0303 - Chianti red
51 - dark beige upholstery
A02 - USA specs - sealed headlamps, speedo in miles, rear window defroster, reverse lamps and side markers.
013 - front bench trim, rear seat in passenger compartment and interior trim.
507 - vent wings in cab doors
508 - vent wing opposite sliding door.
11 - week 11 (71)
2 - tuesday
7953 - ? unknown number set
UA - USA port california
2310 21- Kombi with single port 47BHP motor.
Araon said:12 september 1968
although it was probably built within a few days of this date as this is the factory order receipted date.. so instead of a born on date more like a conception date.
tubdub said:i could use some help too. here is mine
12 107 465 E
thanks for any help
wibbler said:Hi folks, just wondered if anyone has come across the M code 213. Cant seem to find what it stands for anywhere.
Cheers all.
sam@bugeyeddesigns said:Oh i've found the other one!
Can anyone help me work out the date it was built?
it reads:
12 9
793 794
21 426 508 521 790
UH 2211 522552 8020910
Thanks very much!
Speedman said:sam@bugeyeddesigns said:Oh i've found the other one!
it reads:
12 9
793 794
21 426 508 521 790
Thanks very much!
12 9 = September 12th 1967
793 = Production number indicating a special note in the German licence papers, saying that a Trumatic SB2000 gas heater has been fitted
794 = no known code yet
21 = 1600cc 4spd
426 = M Codes 020, 089, 511, 524
020 = Speedometer & odometer in Miles
089 = Laminated windscreen
511 = Padded dashboard and dashboard lid
524 = USA & Candian specifications (covers Ameriacn spec lighting)
508 = Ventilation windows in all sliding doors
521 = With chrome trim, with sunvisor with mirror
790 = no known code yet
UH = USA San Antonio Huston
2211 = Microbus, LHD, Sliding door right 7 seater
522552 = colour code but it doesn't match any of the known ones (can you check it again as theres a couple similar)
8020910 = 1968 chassis number
8)
David Eccles said:I was using the same bible to decode a plate from a 72 mint Devon (feature bus :wink: ) today and got into the E (Emden built) bit..had not come across it before apparently only 67 - 73 export (mainly US) models but wondered if all Devons of that time also built and shipped at Emden as by then Devon were importing big time...so who has a Emden built bus out there?
Speedman said:tubdub said:i could use some help too. here is mine
12 107 465 E
thanks for any help
Just to add a few bits to Araon's work...
12 - 1971 bus
107 465 E - serial number E=built at the Emden factory
0303 - Chianti red
A02 - Group code for 020, 026, 089, 102, 206, 506, 511, 524, 525
026 = With activated carbon container for absorbing fuel vapour
102 = heated rear window
206 = Inner rear-view mirror, with anti-dazzle
506 = Brake servo and dual-circuit brake control lamp
525 = Seatbelts for USA & Canada
11 - week 11 (71)
2 - tuesday (tuesday 16th march 1971)
7953 - ? unknown number set (production planning code - serial number for factory use only)
:wink:
