Some photos from the scrap book:
Dizzy blank with cap to bung up the dizzy hole.
All painted
Drilling the vac ports in the manifolds, all 4, then use some barbed fittings. I bought these off eBay for R/C cars.
Tapping the holes
Nipple fitted with thread lock, make sure the inside of the manifold is clear of any crud though.
Repeat for all cylinders.
Vac plenum chamber to smooth vac signal. Use silicon hose to connect to the manifold ports. This is 1.25 inch drain pipe with ends. Just drill these and screw in the barbs, make sure they are sealed (use thread lock or epoxy glue once the thread is cut). Then clear out the swarf and glue the end caps on. 4 connections from cylinders, one to the megajolt.
Coil pack from a ford fiesta, this is gen2 so I needed to make up the leads. If you get a mondeo gen1 then you can buy leads easily. Note the firing order is 1432, and as it is wasted spark, 2&4 can be swapped for a neater instal. The standard ford firing order is 1342 I think, so you will need to take care. Just follow my wiring.
Edis module located on the top coil mount and I used a self tapper on the other end.
The wiring is simple but you must connect all earths together at the edis and use quality screened cable for the Sensor connections.
