Shaunb said:I had exactly the same issue on mine, just stalling on idle and aproaching junctions!
Found the two rubber sleeves on the air inlet split. No more issues.
Bod said:Hi Lard, thanks very much for letting us know, I think I will source a pair of the split ones and change mine. Cheers, Simon.
Gütterßnipe said:Ok, I got both boots replaced today without removing engine/alternator/carb/fuel pump etc.![]()
It took about 2.5 hours which isn't too bad considering I've never done this before!
Real easy really - no need to ever do more than what's listed below.
1/ Remove hoses from fan and air filter - I trashed these as decided to replace with new![]()
2/ Removed front tinware
3/ Removed stock air cleaner/oil bath
4/ Removed the 4 heat riser bolts from muffler these were seized and took a lot of WD40
5/ Remove nuts on L/H intake manifold
6/ Loosened nuts on R/H intake manifold
The rear nuts on the manifolds proved to be the biggest problem :evil:
7/ Remove nut bolted onto crankcase below intake manifold center section
8/ Loosened the four band clamps holding on the rubber boots
9/ Cut the old rubber boots off the central manifold with a Stanley knife
10/ Removed the L/H intake manifold
11/ Slid the center section an inch or so to the left to clear the R/H manifold
12/ Installed the new boots, (made sure the jubilee clips were in position first)
I'd bought tough urethane ones that were not so flexible so the R/H one was a bit of a sod to fit, but still squeezed on without too much fuss.
Everything went back together in reverse order of the above - a lot quicker!
Dead pleased with myself so took the bus to the beach :lol:
Spence
Gütterßnipe said:Bod said:Hi Lard, thanks very much for letting us know, I think I will source a pair of the split ones and change mine. Cheers, Simon.
I replaced mine a couple of years back with the engine in situ.
Here's what I posted........
Spence
Spence
