Dash pod glasses
mike202
Sep 3, 2011
2,544
628
Northumberland
Anyone come up with a neat way of fixing this problem? :?:
The flat glass over the speedo and fuel gauge dials moves around when I'm driving and rattles when I go over a bump. :roll:
This is because the thin metal ring that holds the glass in is loose, the plastic mounts are brittle and broken off over the years.
I suppose VW were trying new types of plastics around this time and some age better than others. (thinking of the '70 fuse box as another example)
Or should I just put up with it?
loose glass
the ring holders for the glass
broken mounts for the metal ring holder. In the pic you can just make out the bottom three remain but the other five have snapped off.
hello
all of mine had broken off
i used clear mastic as is flexible
and put in glass then retainer then a pea size blob next too snapped off plastic bits
look ok now
and clear so not see if i put two much on
