Have a 1600cc engine fitted with twin dellorto carbs CB performance linkage, I can't seem to get them to fully open.
My van is a 73, I have fitted a new accelerator pedal, hinge & spring behind it and accelerator rod along the cab floor.
The biggest problem is that the carbs are not snapping shut causing the engine to rev a lot at idle.
I have fitted a strong spring to the linkage and the engine roof to try and pull it back shut, which sort of works but not great.
If i dis-connect everything the accelerator pedal has spring in it, I can pull the cable back and forth quite freely, and the linkage shuts ok, but when everything is connected and I start to drive the van after a while I get high revs again at idle.
Is there anyone in the Leicester area or anyone going to the bus stopover who can have a look at it for me?
