Hello,
I've taken off the 6V flywheel off my engine without marking it, because I'm changing it to a 12V from my previous engine.
Problem is I don't know how to orient it now.
It has two balance holes drilled in the side of the rim, but can't see any balance markings on the crank.
Without taking the engine apart and balancing it what is the best way to install this used flywheel?
The original flywheel did not have a gasket between it the crank, should I use one? If so the metal or paper one?
Thanks for your help.
Andy
Andy
