disc brake conversion
http://www.futbus.com[/img]
[/url]
Looks pretty good to me, although I'd like to see a bit more detail! The price is pretty good too, especially for the DIY kit - I've bookmarked it for when I have some more pennies!!
I say go for it, it looks like a great way to upgrade your brakes without going down the Porsche route...
those are some phat discs and calipers :shock: i doubt youd have any problem stopped fully loaded on those :wink:
What price btw?
i have spoken to 247 engineering and they have said there is a possability of a discount if a quantity of kits where ordered depending on diy or not, anyone interested?
I would if I could but i'm in the bad books at the mo, for spending money :(
I've been on there site a while back there kit does look interesting pity the site doesnt have a little more info/pics.
Good luck and get the pics up after :D
Araon said:
...I've been on there site a while back there kit does look interesting pity the site doesnt have a little more info/pics...
I emailed them earlier and got a very quick reply - they use Audi A6 or Passat calipers, I'm definatelt going to save up some pennies and invest...
Justin & Mutley said:
giraffeinbath said:
Is it possible to get them in a wide 5 pattern?
They're working on a kit for wide 5's at the moment apparently!!!
I'd be up for going in on a bulk purchase thing with some of you guys on a wide 5 set if they provide that as an option and a bit of discount was available. :D
Does anyone know what discs they use, size, and what wheel size is needed to clear the set-up??
What about the proportionng front/rear valve thingy that disced-up busses have installed as OE in the factory ?
Would such a thing be included in the kit ?
James
That does look godd - take it you can use normal 14 inch steel wheels :?:
288mm would be Audi A4 or Passat 1997 up probably. 46mm tall for use with ATE calipers. The only other 288mm discs I saw were 25 ish mm tall. Not badly priced either. Are those yellow calipers in the pic ATE? Any ideas on what rears fit a bay best?
