Loxy
Dont forget that some engines are "designed" to drip oil - the oil breather attaches to the air filter & there is also a pipe that goes down through the tinware & has a rubber end on it to allow oil to drip out
Loxy said:Dont forget that some engines are "designed" to drip oil - the oil breather attaches to the air filter & there is also a pipe that goes down through the tinware & has a rubber end on it to allow oil to drip out![]()
aogrady said:Loxy said:Dont forget that some engines are "designed" to drip oil - the oil breather attaches to the air filter & there is also a pipe that goes down through the tinware & has a rubber end on it to allow oil to drip out![]()
Is there? Didn't know that! Got a piccy?
Alistair
VWAIRCOOLED said:aogrady said:Loxy said:Dont forget that some engines are "designed" to drip oil - the oil breather attaches to the air filter & there is also a pipe that goes down through the tinware & has a rubber end on it to allow oil to drip out![]()
Alistair
It's just an old skool crankcase breather system,any vapour will be sucked through the airfilter though a rubber pipe,any liquids will drip out through the built in metal pipe and onto the floor (not allowed on modern cars).I don't think you'll get much dripping on an engine in good condition though.Maybe if the rings/pistons are worn you'll get some dripping.
