Do I need to remove my front beam?
Webbaldo
Mar 11, 2014
756
I'm gonna be starting sorting my front brakes etc soon on the bus and have a problem.
If my beam is rust free and bus floor is OK is there any reason why I have to remove the beam to replace suspension/ball joints/brakes/servo etc? (not changing beam)
I can jack one wheel up at a time fine at the minute but cant do the entire bus front, reason below
My drive is sloped, the bus is parked sideways and I cant move it on to any level surface (don't have one and bus isn't driveable)
I also cant turn it the other way to jack end on (which I do with the beetle)as I cant block the driveway with the bus as need daily access. (the bit where is would fit blocks rest of the drive and street parking is a mare.
Im assuming the only bit which needs actually sorted on the beam itself is the needle rollers on the end?
You can do everything with the beam in situ. If you can get past the kneeling on the ground bit, then the van acts as a useful beam holder when you are doing the work!
