VeeDubMan
I've mulled this over loads and have come up with the following solution for the seat belt on the cooler box side of the rear seat:
Normally it's a roof mounted mechanism for the centre seat of a Vauxhall Meriva but seems to work just as well flipped over the other way. Beauty is that after using the belt, the clips (there are two for the hip area) can be undone and the belt recoils so the bed can be raised normally.
Plan is to weld in a couple of seat belt mounting points behind the top of the seat and mount it there. My big concern though is that the fuel tank is directly below and I'm worried about potential explosions with welding heat/sparks and petrol fumes!
Am I right to think that and should I play safe and drain the tank first? Would also give me the opportunity to remove the R7 pipes and fit R9 I guess.
Thoughts appreciated.
Steve
Steve
