Scott-Westy
just got the JK conversion kit after my 71 calipers seized
parts turned up today
I got 2 brand new ATE later style calipers 72> and new bolts
1 set later style thicker pads and fitting kits
flexi hoses (ordered separatly)
conversion kit comprising shims and top hat bushes
fitted one side in about 30 mins. I had to use one thick (later) and one thin (early) pad to get them to fit in the caliper but they are self adjusting so im not too concerned. when they were fitted both pads had about 1-2mm play before disc
this is the new caliper bolted up
and the top hat bush which allows the later (larger bolt) caliper to fit onto earlier buses
and all bolted up from behind, a shim spacer is placed between caliper and knuckle to get proper alignment with disc
and finally new flexi on
bent brake line to fit no probs, just other side to do, bleed brakes and we're away. question: do I smear copperslip over back of anti-rattle plates between them and pistons?
seems a good kit for other people in this position.
