Early/late spring plates question?
faux
May 11, 2007
3,990
Newport, South Wales
Does anyone know when the springplates started to be notched where the brake line goes through it?
On my 69 there was a hole but I had to remove the brakeline to get the plate off. I have seen some (including creative adjustables that are notched so you can just slip it over the break line.
I assume it is August 71 on......but would like to know exactly for the next time I offer to help someone lower thier bus :)
Cheers all
I didn't know the brake pipe went through the spring plate. It goes through the hub carrier and a support bracket on the A-arm. Could you post a picture of what you are referring to?
I think this is what he means? SRs Bus with horseshoes on.
Hi
I haven't got a picture to hand but I mean the hard brake line not the handbrake cable.
Basically, when I changed the springplates on my 69 for the creative adjustable ones I had to take the brake line out as it passed through a hole in the spring plate. On the creative one it had a cut out so this would slip out without removing the hard brake line.
I just want to know what year these cut out sections were introduced as I will be changing the springplates on my 71 at some point and want to know if I need to do it before I sort the brakes. (I don't want to have to bleed them twice.)
Jon
