Electric Fuel Pump
mole
Jan 20, 2009
85
Pontypool
I was advised that I probably needed to change my fuel pump(mechanical) However I've discovered it is an electrical one does this still apply....Original post below thanks............................................................................................................................................................... Recently imported a 1972 Bay window Westy from the U.S....Drove it back from Kent to Wales no probs.Haven't driven it since only 20 miles to have the lights sorted and 20 miles back.Driving back from having the lights fixed it cut out(bumped started) and it seemed to be running strange...or stranger than when I'd taken it in (?)Anyway got it home and had the battery off to charge it put it back on to start it.It started after about ten turns but still cut out,also as if there was no resistance when pressing the accelerator.So checking in the engine bay and a strong smell of petrol,took the dipstick out (don't know why) to check that....the level was a thumb over the required limit and smelled of petrol.So drained the oil out but I would suggest more petrol than oil....also took the air filter out and that was deep in petrol...somebody please help ...can anybody explain what's happened ?????Feeling P****d off...
does it have a regulator? if not it could be pumping at too high a pressure however:
More info is required really what make/type of pump is it, how is it wired up ? what type of carb(s)?
EDIT:also where do you live, someone here may be able to help you out.
