Hi, i would say use as large a cable as you can get in your terminal that fits on the fusebox. At the end of the day if you are putting the cable to a 6 way fusebox you are planning to take a fair bit of current from your leisure battery. I have used 4mm and 6mm cables before, at the end of the day you can always piggyback a link across the remaining terminals to get the best use out of your fusebox using 2mm cable. Better to use too large cable than too small. :mrgreen:
