VeeDubSmithy
New member
Hey,
I brought my micro bus in January and I knew it had an oil leak due to end flow. So went about taking the engine out to put some shims behind the fly wheel also replace the seals.
So I googled and youtubed how to do it as i didnt have a clue.
I used one of them dial test indicator (DTI) things and I ended up using a metal rule. Worked out to be about 3mm of play on the fly wheel and that was with the origional shims in there.
I worked it out to be about 8 different size shims I will need. Is that too much or am I doing something wrong?
Also when I check the end flow the roter arm moves too and I dont think thats going to help my timing.
Any advice would be great as I want my camper back on the road!! :roll:
