mr scoops
- Joined
- May 8, 2010
- Messages
- 1,144
- Reaction score
- 0
My 1776 is being collected on Friday so should be with me early next week.
It's been spun up for oil pressure but needs the cam bedding in etc. Squeaky Bum time here!
So. I'm going to strip the IDF's I've got here and see what jets are in there.
I've been advised by Eurocrat the starting point will be;-
28 Vents
125 Mains
200 Airs
f11 Emulsion
40 Pump
55 Idle
So, fast forward and the carbs will be on, it'll be static timed and all on the bench stand and ready to go.
2250-2700rpm for 20 minutes and then oil change.
The next thing to do is run it in, but then it also needs to be rolling loaded. I'm going to get this done by getting it transported to Plympton from Weston, correctly jetted, and then drive it back.
Now, if I've not finished running it in, sitting on the M5 ain't going to do it any good all the way back is it?
BUT, running around with it without getting on the rolling road whilst running it in may cause a problem.
HELP! Advise needed, what do I need to do and more importantly in what order.
28 Vents
125 Mains
200 Airs
f11 Emulsion
40 Pump
55 Idle
