slow-lane-Matt
I hope someone can help... I realise there is no definitive answer - but could someone point me in the right direction.
(I guess this subject has been covered before - did a search on the forum and there are 1000's of posts about oil - so hard to find the right one).
Reading in my VW book it says ask the previous owner what oil they used - this is not an option for me
It also says you must not put detergent oil after non-detergent oil, but you can put non-detergent after detergent oil..
(Is there any way to test for detergent oil...?) - He recommends using detergent oil.
It also talks about synthetic oil, and advises against it as whatever oil used needs to be changed so often, so you pay more but don't get the longer life benefits....
He recommends "Mono-grade heavy duty api service Se-cc Military standard - 30sae" but I suspect if I ask for that at CAF they will laugh...
Is the answer to drain, flush install magnetic drain plug (I like the sound of them!), fill with good quality oil 30SAE non-synth/detergent oil - run a few miles, repeat..., I guess that would work - but is there an easier way. Are magnet sump plugs a standard part or is there a special bus one...
At the end of the day does it really make a difference ...!
Any advice gratefully received...(book used How to Keep Your Volkswagen Alive), the official VW Manual is not much help as I guess oil has advanced over the last 40 years...
Also a bit off topic - where's the best place to buy points, plugs, fan belts - can standard modern parts be used from any supply shop - or are these all
specialised parts only available from the specialist mail order suppliers...
...from http://www.thesamba.com/vw/archives/manuals/aug68bus.php" onclick="window.open(this.href);return false;
